should be 32 mm. bizarre thing is that i've seen 32 and 36mm axle nuts from Subaru dealers. i've gone in to get just the axle nuts before and had them hand me a 36mm nut pulled right off the axle from vehicles that usually have 32mm nuts in my experience. so it should be a 32mm, but i have seen 36 on a couple of occassions.
i've sheared 2 1/2" sockets and one 1/2" breaker bar, moving up to 3/4" socket wrench was an excellent decision. makes axle nuts a breeze. use a torch if yours is tight and you don't have a 3/4" set. heat the nut up for one minute and immediately attack it with your socket.
