Leaderboard
Popular Content
Showing content with the highest reputation on 06/17/19 in all areas
  1. Good to know for anyone looking at importing a hatch from the US to a RHD country...
    2 points
  2. My first build log i've actually posted somewhere, picked this 1st gen up from texas and had it shipped up to me in ohio, the plan, is to 100% restore back to original, and make it a new brat again
    1 point
  3. Well the pressure switch tells the ECU that it's PWM signal to the solenoid was recieved and effected a change in the oil pressure going to the AVLS rocker assembly. So until there is a load on the engine above a certain RPM, the AVLS pressure switch doesn't receive oil pressure. That's also why I think the head got cracked. I don't use any torque wrench on them. I use a short ratchet and choke up on the head.... but years of industrial machinery taught me 1/8" NPT sending unit torque values and the various strengths of soft materials like brass and aluminum. My hands are calibrated instruments of torquing. GD
    1 point
  4. You should thrown the fail-pro's in the fuckit bucket and buy some proper Subaru 642's or 770's GD
    1 point
  5. There is some noise. I got the drivers side apart and I think it might be the bearing. With the knuckle out of the car and on the bench I can feel the bearing better and there's a liittle scratchiness to it. Ordered an axle for the left side and both wheel bearings/seals so hopefully that fiixes it.
    1 point
  6. Thanks for the update Ritchie! Glad it all went well! My brumby is currently dash-less and is RHD so I could’ve got the required pics for you. But I’m a little late to the party for that! Cheers Bennie
    1 point
  7. Hello all, just an update on this in case anybody wants to do this in the future. I completed the conversion, pretty straight forward really, the hardest part was cutting a hole on the nearside for the heater blower intake and spot welding on the rain deflection plate under the scuttle panel. Otherwise it was easy enough.
    1 point
  8. Get on it Jono! Now is the time to be collecting bits for the Gen1 Liberty in my opinion. They’re still available in the yards, can be had for cheap on gumtree too atm. But like the L series, this is the death-nell for these vehicles being common and real easy to get parts for! I ran the engine today to show my dad. It’s sat for a week - and started no worries AND without any lifter tick. I’m pretty happy with it. The oil is milky so there’s a head gasket to be sorted but I was going to do that as a matter of preventative maintenance anyway. It didn’t take a lot of water, the sort of amount you’d expect for a cooling system that’s just been filled and run for the first time. Cheers Bennie
    1 point
  9. I'm about 75% on getting them off by hand. The 06+ cars with the pretzel header are a bit tighter but I'm 6'2" and hands to match. I've worked with this same pair of hands extensively over the years - indeed it's rare that I use any other pair. They say the average grip strength of 25-35 males in the US has decreased by something like 25% since 1980. I guess with the combination of video games, software engineering, Army, heavy industrial, and automotive I have the hand strength equivalent of your average super hero. And later in life probably a scorching case of carpal tunnel. GD
    1 point
  10. All this garbage and back n forth and the guy never answered my simple question. Why? What problem are you trying to solve? I have no time for games. I'm here to help people solve problems. It's my only real function here. It's not as if I need to ask many questions in this town. So what's the GD problem you are attempting to solve with swaptronics? GD
    1 point
