Leaderboard
Popular Content
Showing content with the highest reputation on 06/22/19 in all areas
  1. The breather tube in the far back corner. It sticks up into the baffle area covers by the rear seperator plate. Uses an O-ring there to seal that drain back tube for eh PCV. Keep teh PCV from passing oily fumes intot eh intake. Not the Pick-up tube.
    1 point
  2. Subaru heat shields are notorious for rattling. And your symptoms (low RPMs, light-load, decelerating) seem to point at heat shields. BUT, heat shield will also rattle with the car stationary. And the rattling can be quite loud when the engine is started. If you cannot create the rattle at zero speed, then it is most likely not the heat shields.
    1 point
