Leaderboard
Popular Content
Showing content with the highest reputation on 07/07/19 in all areas
  1. Hey moosens. Some respect for the elderly. Bought that 05 in the summer of 04 so it's 15 years old. Leaks plenty of oil... Need your driveway resealed, I'll drop the car off.
    1 point
  2. There is no relay in a stock 92. It is a common failure for a connection in the circuit that applies power from the start position of the key switch, through the transmission safety lockout to the back of the starter to become high enough resistance to make a click from the starter, but not enough power for the solenoid to pull in far enough to close the contacts that apply power to the starting motor. There are a bunch of threads about "the relay mod" on this forum. You can verify that the cause is this by using a medium size piece of wire from the little terminal on the starter solenoid to the + battery terminal. If it cranks, it's this common problem. The other click no crank is caused when one of the contacts in the solenoid wears away enough so that it no longer makes reliable contact when closed.
    1 point
  3. Subaru heat shields are notorious for rattling. And your symptoms (low RPMs, light-load, decelerating) seem to point at heat shields. BUT, heat shield will also rattle with the car stationary. And the rattling can be quite loud when the engine is started. If you cannot create the rattle at zero speed, then it is most likely not the heat shields.
    1 point
