Leaderboard
Popular Content
Showing content with the highest reputation on 07/20/19 in all areas
  1. Hey all. Thought I would share a new to me discovery about Subaru Ignition lock cylinder replacement. I had a customer who's 04 Forester Ignition lock failed. Seized up, wouldn't return to "off" position so was draining battery in ACC. So, I call dealership, talk to them about ordering a new lock cylinder. Now, I've done this I think 3 times in the past. Always purchased a new cylinder and customers then just used 2 keys, 1 for doors, 1 for Ignition. Not a big deal as all those cars had keyless entry, so they didn't really need the "door" key ever. Now, for this Forester, the customer does not use keyless entry, and wanted all keys the same. So I inquired from dealer this time, is there a kit available to replace all 3 lock cyls (Ig., Drivers door, glovebox) in the car with matching keys? Well sure enough, AFTER I ASKED, they tell me "oh, yes, there is a whole car kit" It's $60 dollars cheaper than just the Ig. cylinder. DOH! Why the HELL don't they volunteer that info! Anyhow here's the kit for a Manual trans, 04 Forester. I imagine kits for other models are available too, but I haven't confirmed how many. Comes with Master key (top), Sub-master (middle w/code tag) and Valet (does not operate glove box) IMG_0101 by Dans Subaru, on Flickr
    1 point
  2. His 2011 Forester will have the FB engine. Texan's video is an old SOHC EJ, not the same. Plugs are center of heads, horizontal. It's a coil on plug engine, so got to remove the coils first. They are 14mm headed spark plugs, so you'll need one of those type sockets. tricky, requires just the right length extensions. Possible to do in place, but easier if you lift the engine a bit on each side as you service them.
    1 point
