I don't know if you'll have the following problems where you live, but I did here.
The Neutral Safety Switch (on the tranny) gave me problems. I had to replace it on the 95 because it was sending incorrect signals to the Transmission Control Module and the torque converter would not go into lockup. On both the 95 and 97, the voltage was not going through it to operate the starter solenoid. So I added a push button on the dash to bypass the ignition switch and the neutral safety switch.
I had to change one transmission because reverse quit.
Here is why I said they will take a beating. Both cars are Right Hand Drive Legacy Wagons. My wife has almost 700 mailboxes on her route. When she has a package she must turn the engine off and lock the doors when she gets out. It gets started and shifted more than a 100 times every day. I've only had to replace 1 starter. The 95 has over 467,000 miles on it.
Lucas makes great products.
If you have time, check out this article. Then go to Products. Their (GM) Shudder fix is amazing. I've seen it work every time. https://www.lubegard.com/technology/
Excerpt from the page: In 1972, the Endangered Species Act outlawed the killing of whales and the use of materials derived from those animals.
Automatic transmission failures went from less than a million units in 1972 to over eight million units a year by 1975, due to the loss of sperm whale oil additives.
