You've got  DOHC head bolts from an EJ20g or EJ25D.  I made this mistake once years ago and it's excactly what happens.
	Since the DOHC bolts are deeper in the heads, under the camshafts basically, they are too short and only engage about 4or 5 threads instead nearly 20. when used in the SOHC engines.
	I will bet money on it.  Proper length head bolts won't strip that easily.  Unless maybe your Torque Wrench is WAAAY of calibration and you really put 100 lbs on it.
	Now, you've got 2 striped holes though........And if it indeed is a result of too short bolts, you've still got a good amount of useable threads deeper in the holes.....not enough for the stock bolts.  They would only catch the threads on the very tip.......but, tell you what........7/16th fine thread all thread is so close to M11 that the threads match for about 2"
	Cut the 7/16th fine thread (high grade) to length of the entire hole int the block +thickness of head+ an extra 1~1-1/2" and use nuts.  Viola!  redneck head studs.
	If you drive those studs ALL the way to the bottom of the striped holes, they will hold.
	My 2.2 in my wheeler is running this setup.  Been great for 5 years, probably 25k~35k miles so far.
