Leaderboard
Popular Content
Showing content with the highest reputation on 10/27/19 in all areas
  1. Wait, is this a SUBARU dealership? If so, should be easy to get documents showing what parts have been put on the car - if they serviced the timing belt system, you want to see more than just the belt listed as mentioned above. The toothed idler is often the point-of-failure, not the belt. maybe push them for some little powertrain warranty?
    1 point
  2. Theres no way to test engine condition. No inspection or even pulling the engine can verify lower end bearing condition. Anyone that says otherwise is selling you something. 1. Ask how long the head gasket repair warranty is on the vehicle and get it in writing. Standard shop warranty is 12 months, 12,000 miles if you have it done anywhere else. Cut the oil filter open and check for debris and send in oil samples to a UOA joint. That’s all that can be done and an inspector isn’t going to do it. Its highly dependent on how badly you need a car and how much you’re willing to wait. It’s risky like any used car purchase. If you want to maximize chances pass on any car until you find a compelling reason to buy. This one doesn’t sound great unless you get better feedback on the repair, history and timing components. That car needs $400-$800 in timing belt work before I’d recommend going in debt over it....in addition to properly installed head gasket. If you get the sense the mechanic use Subaru gaskets and properly cleaned and bolts properly torqued and new timing kit - buy it. Brakes and everything else are easy relatively speaking, it’s not that worrisome for anywhere to do those. A head job is far more technical and hinges on proper cleanliness, prep, and attention to detail more than just about any other work. How do you feel about this shop doing that? If not, move on until you find one. Any 2010 under a loan needs a new timing kit or at a minimum the timing belt and lower timing pulley IMO.
    1 point
  3. ^^^ what he said sounds good, maybe check for a particle of metallic debris on the sensor too.
    1 point
  4. might have been better to get a significant price reduction, then have a local independent soob-friendly shop do the work. They may very well change a gasket, but will they use a quality gasket and properly prep the surface of the heads? also, wonder if the timing belt systems has been properly serviced with Japanese parts? I'd say its risky even without knowledge of the 'shady aspect' of the dealer.
    1 point
  5. Check the Tone Ring for cracks. It is mounted on the inside of the wheel hub. Maybe the wire on the sensor got pinched or unplugged.
    1 point
  6. Great. Makes you feel good when you find the problem and fix it.
    1 point
