Leaderboard
Popular Content
Showing content with the highest reputation on 12/26/19 in all areas
  1. Hi everyone! Im a new member here. I have never been into Subarus, didn't know much about them (except that they are hard to get parts for where i am from) so i have stayed away from them. My wife has always been joking around that when she gets her license she would want a Subaru (she has seen those WRX STIs somewhere and every time someone says Subaru that car comes up on her mind). So few years ago i bought her "a Subaru" as a gag for her birthday. It was a rusted out Subaru Leone 1982 Hatchback. That car has been sitting since then to have a proper rebuild. So two years ago i found this 86 Loyale for 200 Euros for a parts car (Wifes Leone is 2WD so this Loyale was supposed to be a donor for 4WD). As soon as i bought the Loyale we decided to trash that car a little and we had so much fun - so much that i destroyed the clutch. I got some other car projects going and due to lack of time and money to "properly" do those projects i decided to hop up my motivation to change the clutch on the Loyale and do some winter beating, so i dragged Loyale home from my country side place. To change the clutch i decided to take the engine out (didn't even use a cherry picker, just pulled it out with my buddy and our raw strength). Clutch was pretty much gone. So changing the clutch became so much more Engine was gunky so i decided to re-seal it with new gaskets. So i took it to pressure washer first. Also found out that previous owner had messed up ALL threads on headers. I had my friend drill and tap new 8 holes. (I don't have the pic of new holes) but i decided to build new headers. When i opened up the oil pan i noticed that a lot of junk came out. The car also had crazy lifter noise so i decided to replace cam case O rings that were pain to order. Im not so sure about lifters being sealed in their place it silicone, anyways on of the lifters had came a part so i ordered all 8 new lifters and put it all back together. So i got new exedy clutch for Subaru XT 2.7l, i got my flywheel machined 1.6mm. New water pump, new pulleys, new timing belts and tensioners, new cam seals, new crank seals (front and back), new valve cover gaskets, new cam case O rings, new oil pump gaskets. This car is a parts car for my wifes Leone (which im not going to restore least not before 5 years) and THIS Loyale im building is pretty much trashes. Every part of this old Subaru keeps fighting me and more i disassemble the more needs replacing. I am not going to restore this car, its just for having fun (maybe do some ice racing) and crawl offroad around in my country side forest. So why build so much? I don't know! My friends keep giving me a crap about sinking so much time and money into this old Subaru. I got to admit i became huge fan of Subaru engineering and these old cars are awesome. There will be more to come, currently messing around with brakes (brakes are completely shot - front calipers don't move in any directions, caliper pistons are destroyed and couldn't find new ones, rear drum brakes were braking off everywhere i touched them) i got new brakes ordered from Rockauto and it will take some time for them to arrive. Also im missing those clips that hold clutch release bearing to the clutch fork (been waiting 2 months on those clips) so then the engine can go in.
    1 point
  2. The hose blew before. If you take that into account, ~25% yes and 75% other possible factors lead to it. Likely system was already clogged and the hose was the fuse. If the hose didn't blow and the system was low on refrigerant and all they had to do was add more. 75% yes it's likely overcharged.
    1 point
  3. What part of the line blew? Was it replaced or repaired? What kind of noise? Whirring like a bearing. Screeching like a clutch or belt. Clunking mechanical noise. What is the warranty on the reman compressor? Was the system flushed when the reman compressor was installed? Was the receiver dryer replaced at that time? Was the orfice tube or expansion valve replaced at that time? Was the proper amount and type of oil added to the reman compressor when installed? Some of them come prefilled, some don't. Was new oil added after replacing the blown discharge line? Charging the system would require pumping it to a vacuum and testing for leaks, then charging to the proper amount of Freon and checking low and high pressures to indicate any problems. The pressures are variable depending on ambient temperature. If the mechanic was experienced, charging the system would not cause a problem.
    1 point
  4. 1 point
  5. Everything I have read on this forum, over many years, points to forget about the Hitachi.
    1 point
