An easy way to get the pins out is as follows.
	You need a pair of needle nose pliers to remove and reinsert the circlips, a 22mm socket on a ratchet to turn the crank
	and  a stiff rod of some sort about 18 to 24 inches long
	I only remove the circlip that allows the pins to be pushed out.
	You use the rod to snake past the  connecting rod in front of you and tap out the pin from the back of the  rod you're working on.
	ie, snaking past 3 to tap 1 out etc.
	Use a 3/4" wood dowel as a drift to insert the pin. Leaving the backside circlip in allows you to tap until it seats firmly.
	O.
