Leaderboard
Popular Content
Showing content with the highest reputation on 03/30/20 in all areas
  1. Read my lips: H-E-A-D G-A-S-K-E-T
    1 point
  2. EA81s have torsion bar rear suspension while EA82s have coil springs, so no, the rear struts won't interchange. I think that's what you were trying to say, at least...
    1 point
  3. if i remeber the 25 spline was for turbos only all n/a cars were 23 spline there is some differance between fwd and awd but they would still fit ether rig with out issue i sure the carbed vs non carbed are both 23 spline with other differances but non that would cause one not to work besides by now im sure all 23 splines are the same and wont matter same with 25 spline there are no good choices left for any of them so just get what fits and fill it with greese and if you want it to last for any lenght of time replace the boots with silicone rubber boots always check for play at the shop you get the axles at ive had too many come slopy out of the box and when installed fail in days after install its best to refuse them at the counter than try to get them to replace them after they fail
    1 point
  4. The weather is going in the right direction. Though that can change in an instance. Snow is a dirty four letter word not to be verbalize after the first day of Spring! This is accordance with local shaman teachings. I am currently driving a 2015 Forester Premium 2.5i.
    1 point
  5. I would suspect one or both of the fans. Once the motor brushes wear down and the copper wire it is attached to will contact the commutator and sparks fly. You won't see them because the motor is sealed. Unplug the fan that is not working and see if the fuse still blows. I would check the fan operation without running the engine to get it hot this way. Remove the panel under the steering column and look for two green connectors. Plug them together, but do not make them click (they are hard to separate). Turn the IGN Key to run (NO START) and watch the fans. This TEST MODE will operate relays, solenoids, fuel pump, A/C compressor clutch and then run both radiator fans on low speed then high speed then off, and repeat the cycle until you turn the key off. Let it run through several cycles. You will have the one fan unplugged, so only one fan should run low then high. If the fuse blows when it switches to high, then that fan is bad. If that fan cycles low and high, turn the key off and plug the other fan in and turn the key on and see when the fuse blows. Don't forget to unplug the test connectors. Personally, I would replace both fans. 305k is a lot of run time for those little fan motors. I use Dorman and they seem to hold up good. One fan is listed for cooling and the other fan is listed for A/C. If you end up getting two with the same shroud, just swap the new motor and fan to your old fan shroud. Let us know what happens.
    1 point
