Leaderboard
Popular Content
Showing content with the highest reputation on 06/13/20 in all areas
  1. Oil and Oil Filters Since New, my beloved subaru "BumbleBeast" has been using 20W~50 motor oil on its EA82 engine, (that SAE grade is for our warm caribbean climate) but in mineral form; mainly from Chevron and Motul; and I changed its oil and Filter at the proper interval, around 3,000 miles. When it became impossible to find an original Subaru oil filter on local stores anymore... ...I used the Recommended oil filter in Purolator brand, for the EA82 engine, which is the Purolator L-24457 Sometimes it wasn't easy to obtain it locally, so I used the Equivalent with slightly larger body, Purolator L-20064 However, larger body means less oil pressure on the system, so with time, I migrated to the Purolator L-10028 When newer oil technology came, with the development of Synthetic motor oils, I chose to use Valvoline's "MaxLife" motor oil, which is formulated to be used in Higher mileage vehicles; I adopted it since year 2012 (despite that I've read about it long years ago on magazines, it took some time to reach my Country and more time to lower its price on the local market) firstly I tried "MaxLife" in ATF form on my Wife's car with excellent results, then in Power Steering fluids on her car and mine; finally I switched to this "MaxLife" in Motor Oil also... ...circa 2014, which was a hard year (for me), with big decisions to take... one of them was to use this oil on extended periods of time, which I wasn't accustomed and I was afraid to try, but I gave it a go, and seems like the hardest part was to obtain a long life, synthetic oil filter to go with this oil. It doesn't make any sense to pour a long life motor oil, with a standard cardboard filter, isn't it? So, after searching, studying and analyzing my options; I found a small, synthetic oil filter with long lifespan, designed to be used extended times, and it had very Good opinions and reputation online, in web sites and forums dedicated to motor oils and filters; but this filter is much smaller than the oil filter recommended for the Subaru EA82 engine; which according to modern lubrication standards, is Better, as a smaller bodied filter aids to keep a higher oil pressure in the system, which is ideal for this engine and its exigent hydraulic lifters... you know. Here is the Oil Filter I chose, compared side to side with the older one which I used for long years: The Napa Platinum 41394 is made by Wix and is pretty small, but satisfies the requirements of the EA82 engine. Here are the Specs: here, you can see how this small oil filter, fits on the EA82's oil pump Base: And, believe it or not; I've been changing the Motor Oil on my Subie's EA82 on a Yearly basis, due to two reasons, money is tight and I am not using it so hard as it was used before 2014, since my small family and I, moved from the big city, to a small mountain high town, in the rural Honduras. I've been changing this synthetic "MaxLife" 20W~50 motor oil along the Napa 41394 synthetic oil filter, every December, since 2014, and the Subie runs flawlessly, no problems so far, despite it surpasses 400,000 miles; also the old used oil still comes out pretty good. Kind Regards. ________________________________________________ Extra info: if you can not see the Photos I shared from Photobucket, you can add to your web browser, an extension named "Photobucket embed fix" wich will let you see the photos, flawlessly. Greetings.
    2 points
  2. You need a 5watt resistor for 40 ohms @ 12V, especially when you account for the ambient temperature. I never used a resistor. I found that Toyota solenoids from the same era are much more reliable - I am still running the same ones I got at a scrap yard in the late 80's.
    1 point
  3. OK. And any need to remove block dowel pins? And. I see you are electronics engineer. I fixed the EGR cel code 34 by changing out a transistor array chip inside ecu. Dummy load 35 ohms worked but then down the line the chip failed. So, will try 80 ohm 5 watt dummy load.
    1 point
  4. Long years ago, I found a chemical that doesn't damage anything and only takes a little effort to rub out anything debris, glue, paint, etc... it is a chemical used in varnished wood for furniture, known locally as the "Red Oil" ... let me find a picture for you: ~► https://gatesantiques.com/product/gates-red-oil-for-furniture/ Here is easy to find, locally made versions of it... it takes some minutes to penetrate on the paper / glue \ dirt, then, buff it with a soft cloth such as an old cotton t-shirt, and the glue will be removed, easily. This works in painted surfaces, plastic surfaces, etc... without harming. Kind Regards.
    1 point
  5. well the manual rack wont fit... I lowered my motor so the sti 6mt would fit and am using the longer u joint any ways when the manual rack is there i would need even a longer u joint... i have a leone wagon im building next so ill use it for that. lots and lots of work went down so far, for the front I changed the rubbing in the pockets of the control arms which alone made the car feel amazing... I stripped everything out and under coated it all along with wrapping my exhaust well worth it all even though its a pain. all the sand blasted powder coated stuff was add along with the upgraded bushings and oem subaru bolts. the only thing missing now is the front GR sti knuckle bearings, the sti sealed bearings are being made into 5x100 from 5x114 thanks to my good friend that owns a machine shop super rare no longer made front bumper clips got made from a 3D printer collage kid which made them so good there better then the real ones.. he used some hard plastic and chemical to harden the clips so they last long. looks amazing now with the second trim on the top of the bumper very happy now. with all the new bushings repaired shocks & fixed cross member, it feels amazing drives like its on rails ! point and shoot now feel ! ... I still need a corner balance & alignment done so it will only get much better. straight from japan !! this is the holy grail of part numbers for my car. with this book and part numbers all I can say is WOW WOW..... there is a boat all read in bound from japan to canada with my new parts on it like the JDM skirt kit, the jdm air dam along with much much more things for this car and my other build the Leone Wagon.
    1 point
