Sure thing, today I confirmed a bad ignition control unit with my multi meter. Checking for dwell at the neg - contact of the coil. Multi meter is set for 4 cyl dwell. While the engine would start due to no ignition spark the dwell reading was 0.0 meaning there was no signal to the coil to fire. Meter is connected from yellow wire(red positive) and engine ground (black meter led) with ignition off it'll read about 60°. Not that important. When ignition on it'll drop to zero(power on, no signal) during good start it'll jump up(doesn't matter how far, just means you have signal) with failure the it'll remain at 0.0.(no signal). Found an ignition control unit on Amazon for 27 beans. Woooo!
