No. EA81s, and early EA82s are the only ones with DOJs on the outer joint as well as the inner, after about 1988, they all have a CV on the outer.
If you can get your hands on EA82 rear axles, the inner axle cup from them can be used in place of the outer on the EA81, but it's deeper, so will allow more axle extension.
You will need a 05+ cam gear for the drivers side cam gear to get the correct pattern. The coils from a 10+ outback will work but you need to switch the wiring orientation in the plugs. You don’t need brackets just a bolt to secure them. I had to space the turbo up 10mm to get everything to fit.
