Fixed it, the signal line from the intake manifold came off, for some reason Subaru used the smallest vacuum line known to man then didn't put a barb on any of the nipples go figure. It's ultimately my fault though I replaced the old line with a silicon version years ago which was a little bit more slippery and obviously not the right diameter and it blew off under boost. The manifold line was so crusty it's probably been like this for years, I am surprised it passed smog with that constant vacuum leak.
I tested the system with a compressor and pressure regulator sure enough as simulated manifold pressure came up so did fuel pressure in a 1:1 ratio.
