I agree, the best bet is to source a Distributor for the Carbureted version of the EA82 engine, nothing else.
As the member LoyalLion wrote:
He is new to this, so I'll share here some basic information that might help him:
The Carbureted EA82 engines coupled from factory to 2WD transmissions, came with Nippon-Denso distributors.
While the Carbureted EA82 engines, coupled from factory to 4WD transmissions, came with Hitachi distributors...
Nippon-Denso units have a faster advance curve than the Hitachi counterparts, Also, Nippon-Densos allows you to use an aftermarket ignition coil with average resistance values; while the Hitachis requires their own ignition coil, because going too low or too high in resistance values on the coil, gets a burnt ignition module, faster. Ignition module is what the distributor has inside, instead on points.
Furthermore: Nippon-Denso units are reliable and simplistic, easy to service distributors, they uses an easy clip-on by hand cap and the rotor goes pushed down also by hand only; while the Hitachi counterparts has lousy screws, specially the infamous rotor screw which is the culprit of many horror stories of people being left stranded in the midle of nowhere by a loose rotor screw. I preffer Nippon-Densos any day, in my own humble opinion, they're way far better for many reasons.
I hope this Helps; Kind Regards.
