Leaderboard
Popular Content
Showing content with the highest reputation on 11/06/20 in all areas
  1. Generally found from late 79 production-wise thru the end of the 1600 , I’m guessing 1987 the latest here in the States. 80-84 sedans wagons hardtops coupe later for the hatchback which was labeled an STD , or fleet car for the latter years. I have thought they were long finished (1600) and yet I had come across one of those later hatchbacks in a boneyard and was surprised for sure. They came with rubber mats instead of carpet , and generally not much in features and a very “wipe able” interior. And they became “managed” unlike the early gen.
    1 point
  2. Did you have codes before the starting issue? I would be heavily suspicious that the codes and non-starting are related. I wouldn't to quickly from there. Vacuum leak - very very very common. Start at the air filter and work your way to the throttle body looking for any loose hoses or clamps. Twist each connection/make sure each fastener (bolt, clamp) is tight. Make sure hoses aren't cracked - partiuclarly the smaller ones underneath, etc. Make sure all are fully seated and tight. Additionally you can spray starter fluid around the intake hose (or probably brake cleaner/carb cleaner...if that's safe) while trying to start the car. Or put some gas into the intake then start. If it starts then you can guess you have leak. Are you sure it has a brand new timing belt or do you mean the drive belt? Timing belt would impact starting, not the drive belt. If the timing belt *is* new - why is it new? Did it break, were you chasing other issues, this might help us diagnose? What recent work has been done to the vehicle?
    1 point
