Leaderboard
Popular Content
Showing content with the highest reputation on 11/20/20 in all areas
  1. https://www.amazon.com/gp/product/B07FZ5YKXT/ref=ppx_yo_dt_b_asin_title_o09_s01?ie=UTF8&psc=1 Installed it two weeks ago. So far so good. Good luck, Sam
    1 point
  2. For typical car batteries - resting voltage 12.0 is fully discharged. 12.6 is fully charged. Resting means no current in or out for a day or so. It should take at least 10 hours at 5 amps to get part way charged.
    1 point
  3. They’re 8, 10, or 12 mm. The fender rail bolts (pop the hood and look) or the ones between the door opening when the door is open, and radiator fan bolts are 10mm. If they’re the same size they’re 10mm. If they’re smaller they’re 8mm. if they’re bigger they are 12. Ive got a charcoal gray 2014 parts car but it’s at my office not home so I can’t look. PM me if you want to buy a mirror.
    1 point
  4. We use the Ford F150 frame rail EFI pumps for replacement on the GL/Loyale EFI. Much cheaper and don't have that damper bulb that leaks. GD
    1 point
  5. Fuel down the throttle body will work just the same as down the throat of a carbie. Cheers Bennie
    1 point
