No worries @bratboy1
After reading @Rampage‘s post, I agree with him too. I drove across the Nullarbor over here with a dodgy efi pump. After filling up with fuel I would have to hit the pump to make it work. It got tricky as I would have to start the engine on the residual line pressure, then jump out and hit the pump to get it cranking.
This “worked well” until it gave up as we crossed a busy intersection and stalled. That was a fun “push quickly” to clear the intersection. We got a new pump for the return trip home. Very glad the pump shagged out good and proper in town rather than on the endless Nullarbor!
Do you have a surge tank or is the EFI pump feeding directly from the main tank? If direct feeding you could have a blocked pump - pull the inlet to pump line at the pump and see if there’s a mesh filter in there, it could be full of junk. If so, your pump might be ok.
Cheers
Bennie
