My 2 cents. If you have a fuel pressure gauge hooked into the source fuel line, watch the pressure at idle, 2500 rpm, then after shut off to get some base line readings. Then watch the fuel pressure for 20 minutes after shutoff, it typically should hold within a few psi. If you're feeling frisky and have a bore camera, or even a good phone camera, safely take out the spark plugs after shut off and look inside to see if you can see fuel draining into the cylinders.
Good luck.
