that's it, that's the fuel tank plug, mine didn't have a rubber seal to it, it just seals.
relays are simple as long as you use a 4 pin type.
2 are usually silver, and 2 are gold plated, i don't remember which is which but one of those pairs controls the low current switch, meaning one goes to ground, the other you'll need to find a switch hot but a hot that stays on while cranking. you can test for this with a multimeter and disconnecting the wire that activates the solenoid to your starter so you don't wear that part out, and have someone "crank" with the key while you search for a hot, i don't remember what i grabbed onto but i don't recommend the ignition coil circuit.
the other 2 pins are the high amperage load switch, you run a FUSED hot from the battery with fresh wire, connect that to the high load side of the relay, connect another wire to the last remaining port on the relay which would be the corresponding high load pair, route it around the back of the engine against the firewall and connect it to your fuel pump.
the hardest thing out of all this is finding a switched hot with the ignition key on and cranking.
