Leaderboard
Popular Content
Showing content with the highest reputation on 03/15/21 in all areas
  1. 2 - 44 ohms as the float moves up to down. PayPal is fine.
    1 point
  2. This may help; O. EJ_cr_matrix (1) (3).pdf
    1 point
  3. We use our sunroof all the time. The cable that operates the front one is broken, so you have to push it up manually, but no other issues. I did just buy an '02 VDC that someone has glued the front sunroof shut, but it only has 120k miles on it, so it's been sitting a lot, so I'm guessing the drains are clogged. I will be cutting it open to try to remedy it correctly. I've not had any relay issues. A lot of variables for mileage, but that sounds about right. I don't calculate mine, as 90% of my miles are in town. I hear a lot on the internet about an oring in the fuel pump assembly that swells, and cracks the tab on the metal cap it's under. Dorman even makes a repair kit for it, now. I've not had an issue with it, but we have fairly low ethanol content up here.
    1 point
  4. Passed on to another member who did a 5sp swap and rebuilt the motor
    1 point
  5. Check the CTS for the starting problem.
    1 point
