I cut a used Subaru Timing belt and wrapped it around the cam gear 1 3/4 times and took the other end to the crankshaft and looped it around so the teeth of the belt locked together with a vise grips as a clamp. I had to cut 4 teeth off the belt so it would slip between the cam gears but that was easy and no harm. Worked like a champ to break them loose and lock them to torque the bolt to 58 ft lbs. All of the old seals were junk, but came out with ease as they were a little undersized. The fellow used sealant to hold them in. Silly. I cleaned everything up and installed Subaru seals. Hope to have it back together and leak checked today. The crank shaft polished out well, I think it will be fine. Oil pump bolts and seal taken care of as well.
