Leaderboard
Popular Content
Showing content with the highest reputation on 09/30/21 in all areas
  1. 195/65 15 is the tire size, they are made by "Westlane". Sizes match, brand/type match, lots of tread left.
    1 point
  2. if we 'assume' (dangerous I know, but a starting place....) EITHER; 1. the cat is not 'lighting off', or, the sensor is unable to report correctly (bad, cut wiring, etc.); I have never needed to to try it, but if the cat is NOT working, the temp at its output will be the same or lower than the inlet side. If it IS working, the temp at the outlet will be HIGHER (by maybe 100*F) than the inlet. Try some measurements at the pipes with an infrared therm. Or, get live data and look at the sensor's voltage. One sometimes overlooked cause of P0420 is exhaust leaks.
    1 point
  3. the belt is a quality issue, and sadly, Gates has gone downhill in recent years - i wont use them anymore for timing. Mitsuboshi is the OE supplier and preferred brand for timing belts on these cars. Aisin for water pump, NSK or Koyo for idler pulley bearings, and NTN for the tensioner assembly. These are all OEM parts and what is recommended
    1 point
  4. These aftermarkets are about as light as they get - I don't do any heavy towing either - sailboats that are usually no more than 500 lb. total weight. No such thing as a bumper hitch here - there's simply no load bearing structure in there to attach to.
    1 point
