for the fronts at least, you do not need to remove them.. there is a rubber cover over the top - pop that off, shine a small flashlight in there, and you can tell if it is bad or not.. if you can see the ball bearings and/or rust, it needs replacing. (front has bearings for steering purposes)
rears don't have the bearing so are less prone to problems, but the rubber does deteriorate over time.
