Just put a bit of soapy water on the belts to make them quiet, or just rub a bar of soap on the belts, it’ll work it’s way around so don’t be stressed about having too much or not enough, can always add more if needed.
Cheers
Bennie
Also Trouble Codes can sometimes mean 2 things:
- There's something wrong with the engine/fuel/electrics/exhaust etc., and you may need to replace a part. Or:
- One of the sensors is playing up and giving false readings and it's the sensor itself that needs replacing.
This is true too. But the MT must have the bearing retainers removed to replace the seal as the seal is push in place from the diff side of the retainer. I hope that makes sense.
The gearbox does NOT have to be split to replace these seals for the MTs.
more just buy quality markers Steptoe! I use sharpies and I can’t remove the marks with metho, I think they’d need to be polished out! But I do like your thinking.
Cheers
Bennie
