Couple recent fab projects. R was sick of the factory rear lateral link adjusters either self adjusting or rusting solid in place. Really don't like the idea of having the threaded bit right in the middle. We made up these from some right and left hand bolts, threaded rod, bungs, and 1.125" tubing. Brush painted them hoping that will hold up a little better than our normal rattle can painting. Doesn't look as good and started assembly before they were fully cured because we're that impatient. Used Whiteline bushings, have always just used Subaru in the past, they seem to last indefinitely. These are far easier to install though. Had to cut the old ones out. Replaced eccentric bolts with 14mm bolts and nuts, welded some spacers inside the stock rings to locate the bolts. Seems to work so far.
Finally got tired of using this dilapidated wooden block for the floor jack for our lifted Subarus.
