Leaderboard
Popular Content
Showing content with the highest reputation on 05/25/22 in all areas
  1. You might investigate a propane/butane mix. From what I have read, not as dangerous as it 'sounds'.....I mean, you have 10+ gallons of gasoline in the car anyway.
    2 points
  2. that's the classic symptom of the 'cardan' joint (u-joint) on the steering shaft going bad. To prove it, spray some light lube or even PB Blaster on the joint to see if it (temporaily) gets better.
    2 points
  3. How many miles on the alternators? They typically wear out a brush right around 150k miles, causing low output. I've rebuilt several of the alternators since 1988, 150k is very repeatable. A couple of times the internal regulator or the rectifiers died.
    1 point
