Leaderboard
Popular Content
Showing content with the highest reputation on 05/27/22 in all areas
  1. Old post I know but this thread came up in a Google search and was questioned by others discussing it on FB today. I just checked the crank bolt thread pitch on the original EA82 engine out of my 87 DL and it is without a doubt a M14 x 1.5. I happen to have a metric tap of that size and it threads perfectly into the hole and lines up exact when laid alongside the bolt. I assume other EA82s will be the same.
    2 points
  2. Just got it back from a shop. The passenger bearing was about ready to come apart and the driver was almost seized.
    1 point
  3. It was "fine" back in 2010. Unfortunately physics and reality have warped significantly in 12 years and now it is possible to annihilate the visible universe if you do this. It's actually quite dangerous - an intern at my shop accidentally destroyed a good part of the city of Portland a while back when the cam slipped about half a tooth and he put it back...... he was summarily dismissed and things got better after a few days. I'm told he still has a severe hangnail that's stubbornly remained untreatable despite visits to numerous specialists in Austria. GD
    1 point
  4. This is another one I was meaning to post about ages ago. This swap is into a Williams Wildcat skid steer tractor. Pretty cool piece of kit. From factory it ran the Wisconsin V4 - a popular stationary workhorse engine of that era. Not easy to get parts for over here these days… so what’s an alternative? Throw an EA81 above the location of the old engine with a solid shaft connecting the two hydraulic pumps that are mounted on either side of the engine, directly to its crankshaft. This one utilises a belt to deliver power from the flywheel to the hydraulic pumps: Pics borrowed from here: https://austrak-wildcat.com/wildcat-mods/ And this is the Williams Wildcat: The V4 in place: front view, seat is an addition: Above two pics from here: https://austrak-wildcat.com/2013/05/25/alans-incredible-wildcat/amp/ Very low centre of gravity gave it an edge on inclines, you can drive one of these across the sides of hills that would be considered dicey at best in a regular tractor. Great for slashing hillsides with. If anyone happens to be visiting Melbourne in Oz, head over to Spotswood Science works - they have what I think is the last one off the production line in one of their display sheds. Many of them were construction yellow, which is what this last example is painted in. That’s it for me and creating/swapping Subaru engines into bits of machinery. Now curious if anyone else has any to share, given the lack of responses so far I’m guessing it’s a pretty rare thing to do! Cheers Bennie
    1 point
  5. So I ended up finding some 4cylinder, 2wd, no ac 4running springs. They are perfect. I'm almost level front and rear, and have good travel. The combo of the new struts/springs front and rear is 2.5 inch's of lift with no spacers. Only issue is the rear springs a still a little stiff. The rear hopefully will settle a bit as it's about half inch higher than the front. Also if I lift a rear up, the front will pick a tire about an inch from the bump stop, so they are still a tiny bit too stiff. I am using the 4runner springs on pro comp 4runner struts. I had to drill out the stock upper spring mount to fit the new strut, and flip it upside down for the new spring. All of the spring Mount needed was a little notch to fit the upper strut mount. This is actually a good improvement because It gives you about two extra inches of spring length.
    1 point
  6. I havent measured it yet but I am almost positive. I will need a fuel cell when I swap the subframe from a infiniti G35 into my RX.
    1 point
