Leaderboard
Popular Content
Showing content with the highest reputation on 06/21/22 in all areas
  1. Yes, I'll keep my 2000 Impreza. Wife has an 06 Forester that got a new Subaru Short Block before we bought it. 5 speed trans.
    1 point
  2. No hammering on aluminum cast parts. Oil pump, distributor, big no, or expect it to break. #1 thing I have found to help disassemble these engines without breaking bolts, etc. - Heat the entire thing to 160-190 degrees F. Easiest to do if it is still running, but a space heater and a heat gun will do it also. About 2KW of heaters did it for me. #2 thing, Kano Aerokroil or similar penetrant. #3 patience! Carefully turn bolts, etc. feeling if the bolt is turning, or twisting off. After years of experience, I can usually tell. Once a bolt starts to move, if it starts to get stiffer again, stop, turn the other way, then go back to loosening, until it sticks. Repeat many times.
    1 point
