1) this is the vehicle speed sensor. You can leave it disconnected. This wire connects to a Reid switch in the back of the instrument cluster. I’ve heard of a GPS unit being used too.
2) These are for the rad fan relay. I only remember one wire for my Gen1 loom, yours might have a two speed fan setup that’s a little more complicated. But you might be able to run a fan off each relay with the ECU triggering them as needed. Hopefully someone else will know for certain what’s what here. Mine is an ‘88 series 2 and had the Reid switch behind the cluster in a carb model, if yours is a series 1 you might not have this, best to pull the cluster and have a look.
3) Neutral wire I believe you can leave it disconnected. I recall leaving my one disconnected and don’t have any issues.
All the best with it! Ensure you finish off all the things you want finished before you start driving, otherwise they’ll always be lingering! Your very close now as you know
Cheers
Bennie
