Leaderboard
Popular Content
Showing content with the highest reputation on 06/29/22 in all areas
  1. Drove one hour, 30 mile round trip, mountain roads on just the battery today while starting with the NOCO genius boost. Battery showed 12.47 V when I got home.
    1 point
  2. the EA82 dist into EA81 involved retaining EA81 dist drive cog to install on EA82 dist in it's correct position, chop the excess off below drive cog and chop a hold down ear. That is all I recall reading. Sounds like a plan to retain all the spfi and let it run on EA81. The spfi manifold touches the EA81 block casings so trim some meat off underside of spfi intake manifold, in a dry fit no gasket, no gasket goo dry fit first
    1 point
  3. Yep. Installed a new battery, it was 6+ years old though it did charge back up fine. Used genius boost for starting, pulled day time running light fuse, tried to avoid brake pedal (to limit rear tail light usage). Made it home, put it on charger, drove to work today with no alt. I'll keep doing that until the ordered one arrives in the mail. 6 cylinder subaru's use a three wire alternator (4 cylinders are 2 wire and simpler) with reference voltage the ECU uses to affect alternator charging. In rare cases the alternator will put out less, like 9 volts, due to poor grounding compromising that reference signal. Measure the voltage at the battery posts and ground via the alternator body. If there's a large voltage difference there's a reference wire grounding issue. It's really rare and I assumed it was the alternator, but it was a good opportunity for me to experientially learn to test for it. I've worked on some triple digit number of Subaru's so there's a reasonable chance I'll see it some day and part of my seemingly irrelevant questions.
    1 point
