Take a picture with a cell phone, then enlarge it. Or use reading glasses if you have those. After 40 years old a high percentage of men start to loose close up/small detail vision and the percentage gets higher with age after 40. It would be surprising if you haven't lost close up fine detail vision.
modern bulbs suck in terms of robustness. I think "higher end" bulbs can have better characteristics - brightness/perceived brightness, clarity, color, pattern, but sacrifice longevity for it. So you might actually be better off buying cheaper ones depending which ones you're looking at.
I generally look for ones that favor longevity which isn't always easy to figure out since that doesn't seem to be the dominant concern.
I *think* LED's are the preferred option for longevity but even that, I don't know which ones are quality verses marketing hype. I think GD has posted which LED bulbs he installs? Maybe? If so - he's probably installed a lot of them and has a much better view that those of us just replacing a few here and there.
A friend designed circuitry to keep power supply consistent to lights on big rig trucks to keep the bulbs from blowing as often. Their lifespan was drastically improved. The electrical inconsistencies - temporary spikes etc are what fatigued the bulbs. I would assume that is at least partially true for automobiles as well. And I wonder if daytime drivings light are more susceptible since they're always on when turning the car on/off and engine start up - etc. They see all the instantaneously loads or electrical changes commensurate with those electrical moments. Just speculation but keep your power supply fresh.
