Leaderboard
Popular Content
Showing content with the highest reputation on 07/19/22 in all areas
  1. maybe some electrical contact cleaner sprayed into the switch would help?
    2 points
  2. i think i would try replacing the relay and/or bulbs first.. cheaper and easier... just to verify could be the relay is failing, could be a bulb failing... but yeah, it is possible the switch is going bad.
    1 point
  3. you could try swapping left to right, see if the issue follows, gets better, or gets worse and yes, they are the same left to right on a Subaru. Other brands, no.
    1 point
  4. i dont think it is the brand - i think it was installation error and possibly an issue with the mating surface of the intake... the break looks a bit odd to me... spaced out, and offset... and if you look in the lower left corner of that picture, there is a spot that also looks like it was sucking in air.. as in there was nothing clamping it down/sealing it as in, the gasket was torn during installation, and the one side shifted out of place
    1 point
  5. Don't know what brand you used, but I've never had a problem with Fel Pro intake gaskets. O.
    1 point
  6. Thought I should post a couple updated pics of Blanche, my XT6, since I've gotten her pretty much completed (minus a few little nit-picky things).
    1 point
