Leaderboard
Popular Content
Showing content with the highest reputation on 07/31/22 in all areas
  1. Long Story Short, I helped him to Repair it the best I could, straightened the metal sheet, removed and trashed the old bumper cover and obtained another one, brand new at the Local Kia Dealer, surprisingly there was cheaper than buying an used one at local junk yards; sometimes strange things like this, happens. Then coated it with fresh paint, and "Voilá" it wasn't as hard as I thought... ...the hardest part were to straighten the rear wheels' alignment, as the rear corner hit, had moved the U-joint and moved the trail arms out of specs, the rear tyres were a little twisted towards the center of the car and one tyre was skimmimng one of the rear Brake flexible lines.
    1 point
  2. it might be a possibility... these engines are intended for use 5W~20 or 10W~30 as per the user's manual, But here, at the caribbean, we prefer 10W~30 for sure...
    1 point
  3. Here you can see my beloved Subaru "BumbleBeast" behind one of the Sorentos on which I've done this simple modification, in fact this was the third one and it belonged back then to my Best Friend: my Father, he passed away on late 2019 ... the Sorento now belongs to my mother. In the next photo below, you can see the Metal Cap in its place, covering the filtering mesh at the opening of the oil pick up tube: Notice the small hole on it, something around 1/4 of the total opening's area: Notice how the filtering mesh looks like without the Cap, almost all the cars that I've serviced, looks like this: (No cap at all) But sadly, these engines needs the Cap there to hold the filtering mesh in its place; so what I did to "Solve" the problem, was to modify the cap by empty all the metal on it, so it ends being a simple "Ring" to hold the filtering mesh in its place, as factory intended, but without being restrictive at all. See: Right after reinstalling this ring, I cleansed everything, reinstalled the oil pan (carter) with mega grey silicone, waited some time then poured fresh Valvoline's synthetic motor oil and swapped a brand new oil filter... I did this procedures long years ago, but I delayed the date to share it online, here, as it is a Subaru forum, mainly... then I've been studying the engine's behaviour after this modification; and in the words of the Sorento's Owner: "I feel the engine a little more responsive" ... everything is working fine and the engine runs smooth as silk, even today, quiet yet powerful. This procedure is very Easy, you only need to remove the oil pan (carter) to do it, modify the restrictive cap to turn it onto a holding ring, and reinstall the oil pan (Carter) using mega Grey silicone. A fresh oil change and that's it! I really hope in God that this could be the answer, or at least, this will help the engine to keep a proper oil flow and thus elongates its lifespan. Disclaimer: I am not telling nor suggesting you to do what I did, use all my ideas, my photos and my written information shared, at your very own risk. Additional information, I've done this modification, to three Sorentos so far and their owners are very pleased with the Results; furthermore, I shared this idea on a closed group of mechanics on whatsapp since late 2016 and as far as I know, they swear that it prevents premature wear and keeps these engines from getting noisier with age and mileage. Kind greetings from the Caribbean Honduras.
    1 point
  4. huh, seems like if this hole were small enough (pics?) it itself could be blocked by a little sludge or debris in the crankcase. I also wonder if it makes this engine more reliant on thinner viscosity oils?
    1 point
  5. My three Girls (Mom, Wife and Daughter) plus I, are now with Covid, as it finally reached us somehow... it has been Hard ...but hoping to survive this excruciating chagrin, I'll write again, sooner or later. Greetings from Honduras.
    0 points
