Leaderboard
Popular Content
Showing content with the highest reputation on 08/18/22 in all areas
  1. Rosebud tips are generally used for heating larger areas/pieces, like the knuckle before dropping in your new chilled bearing. Use a smaller cutting torch tip and keep the flame short. Soak some shop rags in water and drape them over things you don't want to catch fire, like cv boots. Find some table top heat pads like for serving dishes or pots at bargain stores for heat shields while heating with the torch. Drill small holes for bailing wire hangers.
    1 point
  2. Found it! Pics attached. I confirmed with KEP that this adapter plate *replaces* the factory timing cover. 1985 Subaru DL = 1808 GVWR; 1964 VW BUs = 2470 GVWR; I'm certain it doesn't love the extra 662 lbs Thanks for the ProTip. I'm also using lots of assembly lube throughout.
    1 point
