Leaderboard
Popular Content
Showing content with the highest reputation on 08/31/22 in all areas
  1. I know that the gasket set may be used for multiple variations, and I may not end up using all of these. I don't want to miss one of these during the assembly stage of my project. I removed the "easy ones" from the picture. A - NOT thermostat (smaller than the included thermostat gasket) B - turbo equipment C - EGR D E F - turbo equipment G - turbo equipment H J K - case plugs? L - case plus for wrist pins? Slightly too big to fit into recessed bore on case! M - compression washer - for what? N O P Q R S - turbo equipment
    1 point
  2. My understanding is that you're safe in swapping the ECUs, as they're the same in both AT and MT cases, and there's an input (via the connector/harness, of course) that informs it which type of transmission is in place. The (automatic) transmission is managed by a separate controller, the TCU, which communicates with the ECU. I assume you've restored your O2 sensor "mod" to its original state.
    1 point
  3. The solenoid grounds through the transmission case. Make sure the transmission ground strap is in place and has clean, tight connections with proper star washers to bite through paint. GD
    1 point
  4. I primed mine using a drill press literally as an arbor press. I placed each lifter upright in a can of oil and then pressed into the dimple firmly for 20-30 seconds using a rounded rod chucked in the drill collet. I watched tiny air bubbles being forced out the bleed hole along with some old oil on each stroke. I did this until no more air was coming out. Maybe 5-6 strokes. This is a very slow process but it 100% assures that you have no air in the lifter and even better, you get a bit of a feel for a defect if one lifter bleeds down way too fast compared to others. I did this process on used HLAs that had been sitting for 14 years in the engine. I've not heard a single tick since the day I fired up the engine. I did new oil pump seals and other common lifter anti-tick tips too.
    1 point
  5. ^ That's different. Here's Ruby Scoo, still plugging away: and my Brumby (red one) that's still stock with the addition of PS from a touring wagon and aftermarket cruise, they're really the only two changes; white one in the background is my mother inlaw's: Cheers Bennie
    1 point
  6. 1982 Brat on 1995 Blazer chassis with 1999 Suburban 5.7 engine....extensive floor and firewall mods! On second year of project.
    1 point
  7. Wow, it's my photo, about 5 years ago)))
    1 point
