Leaderboard
Popular Content
Showing content with the highest reputation on 09/03/22 in all areas
  1. Read your codes from the ECU. Decipher them from the list. Go from there. Sounds to me more like one of the following: - bad or dirty AFM - dead O2 sensor - bad/dead coolant temp sensor Don’t go throwing money at it until you know what the codes are Cheers Bennie
    1 point
  2. I'm trying to do the front brake pads on my '83 Subaru Brat. I feel like I recently did front brakes on either my other Brat or my friend's '89 Loyale I helped him find, but I guess not and I can't seem to compress the piston back in to allow room for fresh brake pads. This is the weirdest design, with front-parking-brake that cable-squeezes the front caliper. How to compress piston? I can't seem to turn to the left or the right, and I can't seem to compress with a C-clamp. The pads on my drivers side were worn exactly like |\ one edge of each pad was starting to rub metal, and the other edge still had 1/4" of pad left. I was getting a bad front-wheel shake as soon as I let off heavy throttle or braked lightly.
    1 point
  3. Duckbills also work and fit in the piston notch a bit better.
    1 point
  4. I just use some needle-nose pliers, push and turn at the same time...
    1 point
  5. They need to be turned clockwise into the caliper. You can buy a tool at the parts store or get a kit from a better supplier. I use the kit ans it a breeze. It also sounds like the caliper is sticking. When you have the caliper seperated put some grease on the pi.
    1 point
