Usually it's a short in the wire somewhere. Check for pinch points inside the door (window mechanisms, hinges, etc. It could also be behind the head unit if it's tight back there. You could meter the wire to confirm. The speaker could also be bad, check resistance while the meter is out. You could also just run a new wire in about 20 minutes and probably call it good.
