Leaderboard
Popular Content
Showing content with the highest reputation on 09/21/22 in all areas
  1. I would not recommend this unless you have proper safety procedures in place and you know exactly what you’re doing and what the potential outcomes could be! Also remember that if the spring doesn’t randomly exit stage left, right, wherever it wants under compression (potentially resulting in serious physical harm or death) that you could run the risk of deforming the spring. And it was the Gen3 Legacy/outback platform that changed the rear suspension to a multi link setup with the coil over shock setup, this started in 1999 in Oz. Cheers Bennie
    1 point
  2. absolutely. I pour it through a cheap cabin filter or whatever you have laying around. As to the clutch issues I imagine you'll know what's wrong when you take it apart but probably a decent change the fork or pivot have failed.
    1 point
  3. WRX 2.0 head gasket should work just fine. Everything else is the same as SOHC 2.5. Very easy to get parts with that little bit of information.
    1 point
  4. 1 point
