Leaderboard
Popular Content
Showing content with the highest reputation on 09/27/22 in all areas
  1. If the tranny end of the axle has slipped out, you might be able to see it looking down from under the hood.. (no need to jack it up) Had a sudden issue with my 2002 Forester after an axle swap.. it was apparently not pushed in far enough.. popped out and made an awful racket when i pulled into the local convenience store.. was pretty obvious when i popped the hood and started looking.. if you can get it jacked up to get under it, also make sure to check the shifter cable for any potential issues (rusted ends, bent cable near the end, and/or fatigued cable)
    2 points
  2. The older I get, the more clearly I recall things that never happened.
    1 point
  3. Thanks !! Heartless that sounds like I could have maybe just maybe forgotten to put the roll pin back in. Crap. I’m hoping I’m wrong. I did two axles recently on two different cars. And my life sucks for sleep and it shows with memory lapses. I can see where maybe I rushed. Praying I’m wrong and praying you’re right at the same time. I don’t mind being a little embarrassed but I don’t like creating more problems while trying to fix one. Will give an honest report back soon.
    1 point
  4. Thanks everyone for your thoughts and knowledge. GD, I know parts support for these vehicles is dwindling, but I feel their uniqueness is part of why they're so cool and why I'm inspired to keep mine. The car is a bit of a hobby for me, not so much something I rely on for a living. ferp420, that is interesting about the 300zx and superbeetle, thanks for the info. I do believe the Sachs numbers I listed are for 4wd unless I'm mistaken. I currently have Ford Tempo springs in my car (with an ej22) and they are a little too stiff for wheeling, but great for street use. I'm going back to stock for the flex and comfort. I wouldn't be opposed to slightly higher damping rates, though. I hope this thread can lead to a discussion (maybe inspiring other threads of the future!) for alternative parts that could keep our cars going, just like conversation on the 4runner struts from Loyale 2.7 Turbo. I'll probably just get the Sachs parts if nothing else bubbles to the surface, but let's kick it off with this: I know that the Ford Transit Connects use the same style strut. There are two generations: 2010-2013 and 2014-present. I have access to the latter. I'll take some measurements and compare some numbers and post back here.
    1 point
