Leaderboard
Popular Content
Showing content with the highest reputation on 10/05/22 in all areas
  1. Sending unit failures may be very rare, but they're so quick+painless to change that it's crazy not to try it first. The only oil pressure related problem I've ever had was four or five years ago - my wife was en route home from work (an hour drive) in the '98 EJ22 OBW when the idiot light came on. I told her to stop right where she was and have it towed home. Unscrewed the sender, screwed in a gauge, verified pressure, stuffed in a used junkbox replacement, and it's still on the road. Why get caught up in complicated speculation rather than trying the easiest fix first?
    1 point
  2. No small project to split the cases and replace the bearings, and there's a lot of "while your in there" things to consider on a 235k mile trans. I've had many manuals apart, and put a couple back together and used them. I would definitely not bother, not with how easily a good used transmission can be sourced.
    1 point
  3. Hey, I was right for once. Glad you found the problem.
    1 point
  4. ok, to close this one out... finally got around to changing the pressure sending unit (one wire sender, threaded into the block under the alternator) - got a new unit installed, wiped down the plug (old sending unit was leaking a bit of oil) plugged it back in, and no more flickering oil light.. it was a bad sending unit after all..
    1 point
