Leaderboard
Popular Content
Showing content with the highest reputation on 10/09/22 in all areas
  1. Google took care of the dig when I searched for carb upgrade of efi or mpfi heads. Look up your 2008 entries I ended up with Subafury's EA82T would you believe? It had a spider and gold painted rocker covers, blue paint on spider was a lot of work to remove. Ended up with too many blocks so chucked his after finding it had never gone well after a coolant leak and pile of steam.. That engine went north from central coast to Queensland then down further south to me maybe 1800km before chucked !
    1 point
  2. No way to know how long it will last. Might be 50k, might be 50. New fluid will help, but obviously it won't solve the problem. And it will still be a gamble every time you drive it. Make sure your never outside the towing range of your AAA membership.... Whatever you think it's worth (I won't get into that, the market is crazy right now), it will be worth a LOT less with a known major problem like that. Look at Impreza transmissions. 3.9 is a very common ratio for the Impreza/OBS in that vintage. They will likely have a slightly taller 5th gear than the heavier Legacy, but it's a pretty small change. Facebook marketplace and brand-specific groups are a great place to buy a transmission. I bought 2 Turbo (FXT and OBXT) 4.444 manual transmissions for $150 through a local group. One has completely unknown history, but still! I bet with a little digging, you could find a nice local transmission for 300 or less. Sure, it's a pain of a job, but if the car is in otherwise good condition, you will add thousands of dollars to its resale value. That's easy math if you ask me. You could probably find a shadetree mechanic doing side work in his garage and pay him to do it, and still come out way ahead.
    1 point
