Thanks all for the moral support (Moosens) and technical suggestions.
Stopped by a local shop today who got it up on a lift and showed those bolts who was boss. No way I could have wrenched them on my back. BTW Moose, 'twas Ferry Blvd Sunoco.
Major hiccup with the Raysbestos 980354FZN rotors I had ordered from Amazon. After installed, the wheels were barely able to turn... even the side where nothing was done to the bearing, simply swapping out the rotor. Tech asked if I was sure they were the correct rotors. He was able to determine they were rubbing on the parking brake assembly, disassembled and put them on the lathe twice to take down this small but interfering ridge.
Later, when calling Amazon to pitch a b&%tch, I came across the following 2 star review:
"The rotor itself is fine seems to be built well. I installed these on my 2008 Subaru outback 2.5l non turbo manual 5 speed transmission.
Install was easy and just like every other rotor. When the tires was installed and torqued down the rotor was pressing against the heat shield and rear knuckle so hard the tire would not spin. I spent about 10 minutes on each rotor grinding off the lip for the drum brakes in order for it to fit when the wheel was installed. Either I got lucky with a factory defect or these just are not designed to fit a 2008 Subaru outback like they say. All in all I got them to work but I'll be ordering a better fitting product since these do not fit as described."
Amazon fully refunded me for the rotors (now working), said keep them and even tossed in a small gift card for the aggravation.
I would have been so screwed, this being our only car right now, had I run into this in my dimly lit work area whilst slithering around on the ground.
