Leaderboard
Popular Content
Showing content with the highest reputation on 02/16/23 in all areas
  1. Jerry makes good ummm , specialty liquor too. Best of luck with it.
    3 points
  2. Thanks Bennie, from where I sit we have a lot of work ahead of us to get the Impreza running but I'm looking forward to driving it. Finally got video from our 2021 Vegas to Reno finish edited and posted on Youtube. Six minute version: https://youtu.be/zaS10G5Nnws Thirteen minute version: https://youtu.be/CzU8stsycP4
    3 points
  3. 1 point
  4. I routinely - like 100 times - have removed the alignment bolt without getting an alignment. Mark the top strut mount bolt *head* and the strut body with a chisel. Take a picture of the marks on the bolt head and strut body for good measure before removing. Reinstall with marks in same position. Very easy.
    1 point
  5. Hi, i can shed a little light, the guy who used to do the mount kit was name jerry, had a place called brats r us in washington state,he is still living and retired, maybe would provide a mount kit. what is needed to do the 5mt, the 5mt clutch disc, and throwout brng, your ea81 pressure plate, the shifter set from the 5mt, the ea81 trans crossmember gets modified, the rubber mounts from the 5mt crossmember, both side ones and the one in center. the 5mt is shorter, requires longer 1 piece driveshaft to be built. jerry made mods so inside your vehicle everything looked/worked as original. If you should decide to sell as is, price range ?
    1 point
  6. yeah, outer joints usually not the problem.
    1 point
  7. I'm right here, guys. Yes the 82 wagon is mine. It actually gotdelivered to Maine today. It may actually be one of the most rust free I have had, although a few minor spots here and there. It runs great and needs a few things, so stay tuned. And yes, Paul is correct, it is paint code 259 Cream Yellow, just like my 84 wagon! Surprise, I also bought the 81 wagon in Boise ID as well!
    1 point
