Leaderboard
Popular Content
Showing content with the highest reputation on 03/05/23 in all areas
  1. yeah, I think if I do anything, I'd lean towards a gas dryer - just thinking about the temperature/humidity cycles until I get to that last few gallons...wait as I type this, I realize a good approach may be to just fill-up sooner! less atmosphere 'head space' . I think I'll start refueling at 1/2 tank and see how that goes.
    2 points
  2. Hi all, I'd like to introduce you to my current project: This is Gladys, my 1987 GL hatchback. I bought her in August of 2021 and she was a wonderful car to have, until she blew her first engine in late October. Two more engines and a blown HG later, she has been sitting on a friend's property for the past several months awaiting her new engine, or rather, her new motor. See, I plan to replace the gas engine in this car with an electric drivetrain out of a Nissan Leaf. Part of the reason its taken so long to get this project moving has been waiting to find a suitable donor car in my price range (>$3,000 USD) but just a couple of days ago I was fortunate enough to get my hands on this crashed 2015 Leaf from Copart for a grand total of around $2,800 So in this thread I'm planning on documenting the swap and any problems or workarounds I'm encountering as I go along. The basic plan for the build is to take the motor from the leaf and mate it onto the existing 4 speed transmission using an adapter plate made by Angus over at http://bratindustries.net, who performed a similar swap on a 1983 BRAT (a little off topic, but he used the third eye mechanism to hide the fast charging port which I think is really neat). Since it's not strictly necessary with an electric drivetrain I'm forgoing the clutch in favor of a direct connection from the motor to the transmission. I then plan to power it using the battery pack from the leaf, stored in the back since I'm planning on a rear seat delete to preserve space and weight. The whole system will charge from a standard J1772 charging port located where the filler neck used to be. I intend to keep the look of the car as stock as possible inside, going so far as to replace the modified center console with an aftermarket head unit that was in the car with a stock unit I was able to find on eBay along with a factory cassette deck. the accelerator will hook up to the control electronics through the throttle cable and the stock gauge cluster will remain unmodified save for allowing the fuel gauge to read out the battery's state of charge. Should this project all go as planned, the car should have the equivalent of a 107hp motor with 184 lb/ft of torque and about 60 miles of range, give or take some thanks to regenerative braking. Of course if I want more range I might decide to upgrade the battery later on down the line, though I think this should be plenty sufficient for the time being. I plan to use as much from the Leaf as possible, but I'll use third party components to get stuff like the brake booster working on battery power Now, this project is still very much in the early stages even though I'm months in already, but I'm happy to answer any questions you might have about the project, as well as taking any suggestions you might have about how to get the conversion done
    1 point
  3. I believe @DaveT did this with the CTS for the SPFI system years ago. Maybe Dave can dig up his post on this info? Cheers Bennie
    1 point
  4. Hey Todd, this website could help with finding parts to the size you need. A mate got me on to it as we look for alternative parts on our MY Brumby/Brat utes… https://size.name/en That exhaust looks MINT! So shiny, but I bet not for long once offroad! Shame the three pipe done sit horizontally flat beside each other for maximum clearance. If you went that way it would probably be easier to fab up your own headers for that setup! Cheers Bennie
    1 point
