Leaderboard
Popular Content
Showing content with the highest reputation on 04/10/23 in all areas
  1. Just following up: The custom bushing is doing fine along with the drop brackets. I'd recommend going this before you need to so that the stock bushing never tears.
    1 point
  2. Just did a parts number check. EJ202 is 14035AA383 EJ251 is 14035AA382 - with the *383 listed as a substitute (which you always need to check it’s legit) You can plug these part number into partsouq to view the pricing and the pic of the item. Postage usually starts at $US17. Item size and weight will see this increase - but even with this I’ve found them to be far cheaper than anything locally in Oz. It’ll be a sad day if this avenue ever gets shut down or subjected to import taxes etc. Cheers Bennie
    1 point
  3. Phase 2 right? The EJ251 gaskets will work no worries. Plug your VIN into partsouq to grab the part number you’re chasing, then do a search elsewhere using that number if you’re not happy with their prices and postage. Cheers Bennie
    1 point
  4. Miata / Accord coil springs, depend on what you want. For a little Stiffer Ride, getting rid from saggy butt with loads, I chose Honda Accord front coil springs on the Rear, Huge imptovement... I suggest you read the article whose link is on my post above. Edit: Here it is ~► https://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ Has further details and photos... Kind Regards.
    1 point
