Leaderboard
Popular Content
Showing content with the highest reputation on 05/24/23 in all areas
  1. It could be break-in related. That said - in a perfectly machined, and perfectly cleanly assembled engine - assuming it is primed correctly, etc - there *should* be NO break-in except for rings - which would be cast iron, steel, and I think the top compression ring is plasma-moly (100% molybdenum) coated..... there's really nothing in an engine that *should* wear that contains silicon. The bearings should float on a film of engine oil and continued excess silicon in my opinion is an indication of sloppy clearance, assembly, or cleanliness. It may wear to a point and plateau there for a very long time - or it may just eat itself in short order. It's really hard to say - continue to do analysis and watch the trends. GD
    3 points
  2. Important to note here that "Silicon" is different than "Silicone" (often found in engine sealants) and also different than "Silica" (which is often found in sand and dust) - these are all different materials with different properties. Silicon is used in the BiMetal bearings Subaru uses for the connecting rod and main bearings: https://www.aclus.com/bimetal-bearings-characteristics.html Having seen the a few of these reman engines fail, and given the track record of this particular vehicle and the dealer doing the repairs - I would guess accelerated bearing wear is the reason for the high silicon. Might be minimal and clear up with more miles, or it might eventually throw a rod. We had one of those engines blow at about 13k miles. GD
    1 point
