Leaderboard
Popular Content
Showing content with the highest reputation on 05/28/23 in all areas
  1. That's definitely at EOL for the transmission. A remanufactured CVT is 6500 for the unitm 8k installed if you don't do it yourself. The valve bodies are a problem, but so is the whole unit. If you're going to do the work, I would just replace the whole transmission. Good luck! For what it's worth, I had a block replaced due to oil consumption. I'm on the 4th block including the original factory block. Two failed ib less than 300 miles due to bad rod bearings. My CVT has 133k on it and is starting to show signs of doom.
    1 point
