Leaderboard
Popular Content
Showing content with the highest reputation on 12/12/23 in all areas
  1. It can be either the canister or the valve. It's easy to replace both and they're not very expensive, just messy because they're located behind the passenger-side rear tire underneath the car and road filth accumulates on them.
    1 point
  2. Only reason to post today is for good karma, good mojo, whatever you’d like to call it just generally good spirits from the once mighty USMB crowd. Funny how things happen. Lost parts that finally show up. Frost has now become the norm overnights so I’m pretty much past my goal, well past really but given the adjustments for life’s events I was hoping to at least be done and have the car running before any real snow. So far I’m still within that margin. Today I should be in proper shape to start this car for the first time in ?? Maybe since 1989 for the car and likely since 2005 for this engine I’m using. No need to post although the cheers will be appreciated. As long as I posted here that’s probably enough to spark the magic. I doubt it’ll be a first crank and run affair. But we can hope. I have to admit to being a bit of a hack at this point in regards to the carburetor. I truly should have lifted the float chamber top and at least sprayed the heck out of it. I’ll have all on stand by and that gasket for the float lid and then some. Hoping I spray carb cleaner in the fuel input and down the throat and get lucky. But I expect that float and it’s valve will be stuck or sticky enough they’ll need attention. Here’s to the weekend ! Cheers!
    1 point
